i have a c4 trans with a stock valve body that has been machined to be a manuel valve body, whenever there is a load on second gear the trans slipps but in 1st and 3rd the trans is solid. i measured the pressure in each gear and all gears got about 145psi but second droped to like 130. would this be a valve body issue? also are stock valve bodys that have been machined junk? thank you to anyone that helps me
