The easiest way to get the pump out of a C4 or C6 is to turn the tranny upside down, remove the pan and valve body, remove all the pump bolts, sit the bellhousing aside on the C4 and then take a large screwdriver/pry bar and place bewteen the forward shell and the rear planetary and gently pry and wiggle till the pump slides out. Make sure you hold the pump by the spine so it doesn't drop off the table and mess it up or leave a couple bolts threaded into the pump a few threads.
hope this helps you.
