i found a 87 aod trans for my 66 fairlane with a 1985 302 will it bolt right up where my c4 was or do i need to make modifications to anything?
The AOD had taken over the C4 prior to '85 so it the bell housing should bolt up. You will probably have to fabricate a mount as well as cut down your driveshaft, and maybe a different yoke.
