i have a C4 with a performance automatic reverse man valve body. it was giving me problems so i took to my usual shop and they did a complete rebuild broke a ton of stuff and we even replaced the converter. now it will only go into reverse and needs to be floored to go forward??? got any ideas? they are on the phone with performance automatic right now
Sounds like a prob in the forward clutch .There are 2 different size(width) sealing rings on the stator support for the fwd clutch,wrong ones maybe..
Remove the valvebody and do some air testing might show up the problem.
Keep us posted on your findings...
I had the same problem with my rebuild. When I looked to see what was going on, the oil smelled burned. Looked further and the clutch pack appeared burned (black). The bearing race showed heat discoloration as well. Maybe you will find the same thing if you open yours up again. Maybe this can help someone pinpoint problem further.
Paul
