1 - 11 of 11 Posts
Is there a big block bell-housing for for the C4 Transmission? OEM? Aftermarket? Where might I find one???
I know there were a few made from Ford that came out to hook the c-4 to the FE series engines, I believe it was an over the counter piece in the 60's for the racers. I have seen a few pop up on Ebay from time to time that will let you hook a 385 series engine to a c-4...I don't remember if it was a Ford piece or some aftermarket unit though...Sorry, I know that isn't too much help to you...but I do know they are out there!
Mike
In the mid-70's Ford full-size cars had C4's behind 351M engines which have the same bellhousing bolt pattern as the 460. So there is a factory bellhousing tht will fit. The tranny I have is a pan fill and the bellhousing attaches to the case with separate bolts (the more common case fill tranny uses the pump bolts to attach the bellhousing). I believe the 351M torque converter has the same bolt circle as a 460 flexplate but have not verified this. I'm guessing all 351M C4's are pan fill because of the needed room for the larger diameter flexplate.
Forgot to mention that if this big block is an FE, in 1964 Ford put C4's behind 352 engines in F100 pickups so there is a factory source here, too. Fairly scarce though, I'd guess.
ati in baltimore md and perf automatic in gaithersburg md both offer bells to FE and 429-460 for the C4.
Dave Shea
S/ST 1818 S/P 1018 H/R 1564
<font size=-1>[ This Message was edited by: igo1090 on 2/24/06 11:54pm ]</font>
Thank you for all the replies! This is for a 335 series engine. A 400 to be exact. Looks like they do exist.
Thanks again.
Mike
The FE to C4 is a myth I have came to believe. It is something with a part number that became misconstrued as a truck number possibly for an Econoline van that never came with an FE. Have never seen a photo of one. The bell would be available through aftermarket adaption. 351M did have a C4 installed on the intermediate car line, I removed and sold one from a 73/74 Torino. I think there was a rumor that it was due to shortage of the fmx at the time.
1 - 11 of 11 Posts
