Could someone I.D. my C4. I need to know if it is Dip Stick in Case on Dip Stick in pan?
I followed the Dip Stick tube and it enters the case just above the pan, and would appear that the dip stick would then actually go into the pan.
Thanks. I need to know if I orderd the correct Torque Converter.
I guess I should have stated the step-case C4 is the case fill....huh?
and hard to be beggars when you have little to choose from for as pics on the net...plus no one is perfect, huh?
