I bought a C4 transmission from a salvage yard. It was bolted to a 302 1974. Took it apart found it only had 3 clutches in it, would not fit 4. Ordered new drum.
Now the flex pate has 141 teeth and is 12in ,it seems to be small.
I am putting this engine and transmission in a 1950 Ford that I am building, not a high performance engine. HELP!
O K now I have a drum sent to me that will take 4 clutch disc. Will it work and with a 302 engine not a high performance. 141 teeth flex plate.
More clutch disks equals more torque capacity. C4s were used mostly with 302s. 351s used the FMX. The C4 can be built up to handle a lot of power with upgraded components, but probably not necessary for a street 302. I assume you're not installing a trans-brake. Good quality friction disks and bands should be sufficient. The C4 is not difficult to rebuild. I rebuilt mine using the BadShoe Productions' video and the shop manual as guides. The video was made pre-HD so it can be difficult to see the detail at times. You can also check out the Ford transmission forum for advice.
FordTransmissionForum - Ford Transmission Forum
The number of teeth on the flexplate is contingent on the bell-housing on the transmission since the starter mounts to the housing. Several different bell-housings were used over the years.
Being that the bell housing and transmission bolt together, I was able to get the torque converter and the flex plate off the old engine.
I have got a new drum that will accommodate 5 clutches.
