Case vent is older style and tailhousing vent is newer, I think the newer one is like 70 and up or so, not sure though. I would say if they are both pan fill they are both good units to use. Hope this helps.
<font size=-1>[ This Message was edited by: Tim R on 4/15/02 5:00am ]</font>
Be careful if you start swapping output shafts.Compare the front ends of the shafts.The early shafts had a recess in the front to allow for a 1/4" longer input shaft.I think dragman64 just did this swap from flange to slip yoke so he may be able to help..
I had a 1970 pan fill from a truck. I put my 1964 tailshaft on it. the outputshaft has the recess for the longer imput shaft. It works fine. The only problem would be if you were using a early imput with a late output. Even then you could make it work with some machineing.
I had no vents, so I put a 90* 1/8npt fitting on the tailshaft with a 3/8 hose going up to my firewall. I have a little plastic breather thingy, that you see on rearend vents, on the end of the hose.
Greg, do you still have those pictures of the output shafts?
-Walt-
1964 Comet 289 C4/3000 stall daily driver
TFS TW, Weiand Stealth, Comp XE268, Rhodes lifters, TFS roller rockers, Carter 625 AFB, Hooker SuperComps
"These go to 11." -This is Spinal Tap
<font size=-1>[ This Message was edited by: dragman64 on 4/16/02 8:25am ]</font>
