41 - 47 of 47 Posts
Ok, but what about the park rod. It looks to be in good shape and I don't think any piece got broken off into the parking pawl like some people I have read about. But I could only get the transmission to manually shift into all 6 gears when the park rod was removed...would that have something to do with the band struts not being in place? Should it correct itself when I get those back on?
The struts being out of position probably caused everything.
Did you mess around with the band adjuster to make them fall out of place?
Discussion Starter #42
Ok Im going out now to put them back into place and then see what happens.
No I didn't even get a chance to see them, they just fell right out when I took the last bolt out of the valve body, so somehow they must have just been completely disloged somehow.
Discussion Starter #43
Just wanted to let you guys know I was able to reinstall the band struts and tighten the intermediate band no problem. I then reinstalled the park rod, reattached all the linkages, got the valve body back on and linked up the manual valve and the kickdown surprisingly easy. Reinstalled the pan with a new gasket, filled her up with fluid, and behold--- ALL GEARS WORK!! She actually drives and shifts alot smoother now than she did before.
I can't begin to tell you how fulfilled I am to have done this with ZERO transmission experience, and on the floor of the garage to boot. The whole job cost me under $50 (gasket and fluid) vs. who knows what a mechanic would have charged me. I cannot thank you guys enough for your help and guidance to help me through this. I owe you all a beer at some point! Now I just have to clean up the mess in the garage.... :frown:
Congratulations!
Well done! Chances are, if the "other guy" can do it you can too, and probably much cheaper. If you want to know what you're really capable of - buy a classic car and maintain it properly yourself.
41 - 47 of 47 Posts
