I have over a 1000 passes on my car. It uses the original 6 cyl driveshaft that came with the Fairmont when my brother bought it. The u-joints do not have grease nipples and I cannot remember ever changing them so I think they are the original Ford ones and they are the small 1310 joints. 3100 Lb car goes 10.70's best with 1.48 60 ft.
Now I would not recommend this for you car but truck 1330 joints may do the job.
I am going to all 1350 stuff because I am getting worried about the tiny shaft under there. I went 1350 because I happened to have a tranny yoke I got from another deal.
I had a problem twisting the splines in these 28 spline yokes. (small input/output toploaders use the same slipyoke) After going through several Spicer yokes, I learned Mark Williams Enterprises offers a super duty unit that is practically bulletproof. However, it uses the #1350 (one ton truck) u-joint, so a new driveshaft needs made. I've been using it for years now with no problems. When I bought it, the price was $170.
Good Luck!
