just want to know if i can put a 26 spline shaft in a 24 spline c4 seeing the trans side of a 26 spline shaft is 24
No ,you cant just fit the shaft in as the 26 spline shaft has a diameter of .839" while the 24 spline shaft is .788".The stator support wont allow the swap.
To use the 26 spline shaft involves a fair bit of parts swapping to do.You would be better of to source out a 26 spline trans to start with.
