I have a C5 tranny behind my little 302 in my 84 Ford Flareside. I was told it has a shift kit in it and I kind of believe it as it will hold first or second to any rpm. None the less I am fixing to flush the torque converter and tranny out and thought I might as well throw a shift kit in to be sure. I was looking at the http://cgi.ebay.com/ebaymotors/TRANSGO-SKC5-FORD-C-4-C-5-TRANSMISSION-SHIFT-KIT-C4-C5_W0QQcmdZViewItemQQcategoryZ34208QQitemZ4590968178QQtcZphoto Are those any good? I was told to stay away from B&M, True or false? What does it accutually consist of to install a shift kit? Someone mentioned drilling holes and changing some springs or something? What all do I need to be aware of?
Also I was thinking about getting a shift servo as well. What would be better in a truck, a H or a C. I think I have a N in it now, is their such a thing? Also im going to do the servo with fluid out but do you have to drain the fluid to change the servo or? I was looking at TCI servos and this one http://cgi.ebay.com/ebaymotors/C-4-C4-C-5-C5-BILLET-SERVO-SHELBY-C-CODE-MUSTANG-FORD_W0QQcmdZViewItemQQcategoryZ33727QQitemZ8017521479QQtcZphoto. Is it worth a poo?
I am just trying to accomplish good firm shifts and hopefully barkin' second. My 302 has a RV cam and ~9.0:1 compression and Edelbrock four barrel ad intake and various other bolt ons if that is pertitenent to this thread.
Anyway I know this thread is long and drawn out, sorry. But if anyone would be willing to point me in the right direction I would greatly appreciate it. Also I cannot afford to just get a complete already built aftermarket tranny, or I wouldn't be asking these questions.
ps. One last question as I remembered it..After I do all this must I readjust my bands and everything? Some say yes and no? But im really not sure
Thanks a lot!
Meh
· Premium Member
The SK-C5 is the kit you'll need and fits c4 + 5 ,all instructions come with the kit.It is as you say change some springs and drill the holes.I think that is the only kit for the c5.That is a basic improvement kit that will firm shifts but not really tyre smoking shifts. If you want that you be best to swap to a c4 valvebody and get a 40-2 transgo kit .Keep in mind though the trans has to be in ok condition too.The kits wont fix a trans that is worn out.
Check the monster thread for servo sizes but from memory the N was small on the apply.For what you have all you need is a factory servo in either R or H .The aftermarket ones are based on the H or C and are fine if your budget goes to them..
You are going to have to adjust the front band anyway if you change the servo so i would do the rear too.
i didnt know a C4/C5 wouldnt hold 1st and 2nd at any RPM.Every one ive driver you can hold 1 and 2 till the engine blows.They were stock trannys.
