1 - 16 of 16 Posts
I'm helping a friend out with his C6 and had a few questions about shift kits and servo levers.
Normally when I build a C4, it's for a hot rod and a no brainer (for the application) to go with a manual valve body. Since this C6 is for a truck and will need to keep the automatic functions what sort of shift kit would you recommend? I see that TransGo and Superior both offer kits.
One of the items that we did go with was one of the billet "R" servos. The servo lever is a new thing to me though. Ours is an "A" lever. I did a search and saw that it has a 1.65:1 ratio. I see that others have a better ratio, but would it be worth changing? How exactly do you change out the lever? I fooled with it a little but didn't see how to remove the hinge pin.
I appreciate any feedback,
Gerald.
Use a 67-2 transgo kit.
Just go with the servo ,leave the lever. Too much servo and lever multiplication can crack the case.
If you really want to replace the lever there is a welsh plug in the front.
But like Greg says. You can split the case.
I have another question. How many welsh plugs does the C6 have in it?
I ask because we found a welsh plug in the bellhousing area and we don't know if it came from the tranny or is just road debris (he didn't have an inspection cover at the time). I check the welsh plug for the servo lever and it's still there.
Sorry about asking, but I don't have an ATSG for the C6 and the Haynes doesn't really talk about any welsh plugs.
Thanks again,
Gerald.
That's probably out of the starter.
There is only one in the transmission.
Discussion Starter · #8 ·
The C6 is up and running and my neighbor tells me it shifts about a 100x's better than before. I appreciate the advice on the TransGo shift kit, it really seems to work well with the Sonnax servo.
One more question for you guys. This C6 is behind a 351M engine and it's missing the inspection cover. Can I get this inspection cover from any engine (windsor) or does it have to come from a Modified engine?
Thanks again for all the help,
Gerald.
Any cover should work.
Discussion Starter · #10 ·
Guys, I measured the bolt hole spacing on the bell and came up with 10" from hole centerline to centerline. I looked at a C6 cover from a 351W and it only had 9" from hole to hole.
Does anyone have a C6 cover with the 10" spacing that they would sell?
Thanks,
Gerald.
just get a chunk of sheet metal and make one.
Discussion Starter · #12 ·
The home made inspection cover works pretty well! Thanks again for the help in this successful build!
Gerald.
Discussion Starter · #13 ·
Another question. I filled the unit with Merc III instead of type F. It seems to shift fine, but it has a shudder when you take off in first. I don't know if it's the engine missing or tranny slipping.
The truck has big tires and not a lot of gear.
Did I make a mistake in the fluid and is going to kill the unit?
Discussion Starter · #15 ·
Definitely has a shudder in 1st gear when the truck first starts to go. The truck has 35x12 tires and I'm not sure about the gear but it feels like it struggles a bit to get going.
I'm going to help him out with a tuneup and see if that helps. If the shudder is coming from the tranny vice the engine, what are some potential causes and how could I help him out with it? He said the truck had the shudder before the build and he's fine with it, but I like to make a project or job as perfect as possible!
1 - 16 of 16 Posts
