My C6 behind the 460 is shifting up into 2nd a bit later than i'd like, and into 3rd gear much too early - that is, low in the rpms. Is adjusting the band the solution to my problems? Should I tighten or loosen it or is it supposed to always be set to the specs in my handly little repair manual - 12 ft lbs then turn 1/4 turn back (or something like that, I don't have the book with me)
thanks for any help you can offer!
Matt Williams
'67 Mustang Coupe 460
It definitely won't hurt to check the band adjustment as this directly affects the 2 + 3 shifts..Go with tighten the adjuster nice and snug and back 1 turn..The early upshift into 3rd can be adjusted with the modulator.Screw in will make the 2-3 shift a bit later..
I think the C6 band adjustment is the same as a C4 or close to it. I would snug the band again and back it off a minimum of 1 1/2 turns. And yes, the band adjustment can affect the 1-2 and the 2-3 shift as this band is what creates 2nd gear.
