I’ve done a 6cyl standard column shift to a 390 C6 swap on a convertible 64 Galaxie. I had to move the trans mount back about 3 inches and that made the front emergency brake cable to short. My question is is there a longer front E Brake cable that can be used? Or has anyone come up with a way to get this to work?
Subscriber
I'm unsure on direct-fit parts, but you should be able to cut the cable and splice/loop another 3" in using wire rope sleeves, swage, etc.
Thanks I will cut and splice if I can’t find a one piece replacement part!
