Does anyone own a set? Wondering what they look like. I have 2 shortened 1 1/8" open wrenches that I use but they aren't to friendly with the small amount of ground clearance that I have.
A pic would be super. . . .
Go to the store and get a cheap, full sized 1-1/8" wrench and cut it in half. Cut the box end to look like a tube wrench... (a slot in the end just big enough to slide over the threads)
Now, you've got the two 1-1/8" wrenches you need to use at the same time to adjust the bars and set the lock nut.
Good Luck!
