1 - 20 of 33 Posts
I'll post a couple later on this evening.
Car is currently undergoing some minor surgery.
Hoping to get the engine compartment painted this coming week.
Here is mine
In the shop now getting a few things done to it.
Like cleaning and painting the engine bay,
putting a new 5.0 in that hole.
Got the t-10 rebuilt and it is also waiting.
Also need to repaint the dash and the rear shelf.
Recently replaced the floor under smugglers box,
had to cut out some of the back of the cab to do so.
Now I gotta replace that as well.
This is my '63 Ranchero project with a 4” static drop and 13 inch Cragars mounted on 5.20-13 Sportaway tires. The badges on the front fenders are the Australian "Super Pursuit" found on XM Falcons which seemed apropos given the Edelbrock tri-powered engine with glass bowled Holleys that is being rebuilt and will make its way under the hood.
Here's my 64. Bought it off a buddy for $500 15 years ago. Pulled the 260 and 2 speed.
Bored and balanced 302
Gtp 40 Heads
Schneider 3/4 cam
600 Summit Carb and Intake combo
Billet Dist
March Serp Pulleys
Spal Electric pusher fan Alum Radiator
AOD Trans B&M Shift kit with B&M Hammer Shifter
My 63 ranchero in Oz. I purchased it a few years ago but it has spent most its time in the shed due to other projects.
My 65 project...
Whereabouts in Idaho??
I grew up in Blackfoot----Between Pocatello and Idaho Falls
Bet you have to bundle up nice in the Winter---no heater in that car
Question on the Radiator--Water pump
I have the same radiator with a driverside water pump inlet.
If you have a later engine and water pump---what lower hose
did you use.
Not sure the one I had with the other radiator will work----besides---can't find it.
did you use.
I just did this on my Fairlane, if its 1 and3/4" on water pump and 1and1/2" on the radiator, try a lower hose for a V8 Maverick.
did you use.
I'm in Mtn Home not as cold as you eastern Idaho guys but still windy. We finally had a decent day yesterday, it was in the low 40's and I took it for a spin. looks like more bad weather in the forecast though.
I'm not sure myself, I haven't had to replace it yet. I just used the same hose when I replaced the radiator. it has an early 70's 302 in it. Might try and run to Napa or whatever and see if they have something close to fitting.
Got this about 6 mos. ago and been driving it every day, it's a lot of fun, get thumbs up almost every day the right front fender has been changed and theres a little bondo by the gas cap and the post dent in the front bumper. other than normal nicks and scratches for a 46 year old car its all there still go the sticker on top of the steering wheel.
1 - 20 of 33 Posts
