To move your torque range to a lower rpm, in effect creating a "smaller" cam, you would want to advance the cam, not retard it.
Check your cam card, as many cams are already ground with around 4 degrees of advance when they are installed straight up.
Any time you advance a cam, recheck your valve to piston clearance as it will be reduced.
Steve A.
