1 - 8 of 8 Posts
Hallo,
I play a bit with the desktop dyno .
Looking how to perform my 351 at next.
My quetion is :
I want to change the cam from hydr. flat to the solid ones .
Would the hydraulic flat tappet cam work with solid lifters also ?
I am thinking a bit on the XE- 274 cam with solid lifter setup .
Now the 351 has ported 302 heads with small chambers (comp-ratio about 10 to 1)
but want to change at next to the trickflow tw heads (now definetly)
Thanks for any response
1) Hydraulic cam will NOT work with solid lifters.(it has no "clearance ramps&quot
2)Solid cam will NOT work with hydraulic lifters.(the ramps confuse the lifters)
3)Solid cam and lifters REQUIRE an adjustable valve train so that you can set the clearance.
Good luck!
Ok,
What solid cam you would prefer for this engine . (want power from 1500 to 6000 +)
C4 with 3.0 rear
The adjustable valvetrain is no problem ,
I love to check that valve-lash from time to time .
The Comp Cams XE274H is a hydraulic lifter flat tappet cam. It should work O.K. IF you have 92 octane (or better) fuel available.Cam should be easy on the valve train with .519/.523 lift. With lower octane, you can 1) reduce the compression or, 2) increase the duration a bit. Perhaps XE284H?? It depends on the combination, weight of car, gear ratio, type of useage.
As B4, Good luck.
Here is my combo :
79´ 351 W
Homeported 302 heads
9.8 - 10.0 comp-ratio
RPM intake
600 Edel vac. sec. /Holley 750 (3310 vac.sec) available
1 5/8 flowtech longtube header ,selfmade X-pipe and full lengh 2 1/2 exhaust.
tranny : C4 with 3.00 rear-gears
tire-size 255/45-15
planed changes (maybe next winter):
twisted wedge heads 2.02 / 1.6
and portmatching the intake
Torque converter choice makes a huge difference on how much cam you can run. What is your stall speed? How much vacuum do you need and is this car something that is going to be a daily driver, street/strip, or what?
If you are wanting a solid cam that makes power from 1500 - 6000 and will work with a stock converter, you'll have to stay fairly conservative. Anything that's much bigger than the Comp Cams solid Magnum 270S requires a higher stall speed. I would think that the 270S cam would suit your needs quite well. The specs are: 224-224 .499-.499 110 l/s +4)
1 - 8 of 8 Posts
