OK... well, my solid cam is gone and will make a lovely lamp.
Enough crying over spilled milk!
I have some serious time limitations... so Im going to pull that cam out the front, wash down the motor and do a swap very fast as I want to go racing on the 12th.
Thank god I am on holidays starting tomorrow.
Soooo, anyone have a recommendation for an OTS cam that would work well with my combo and be comparable to the solid that went? My solid was custom ground and I just dont have time for that.
Solid specs were...
536 int and 545 exh
236 and 242
110.0
Thanks!!!
Why would a hyd break in any better?
Maybe time to go hyd roller if you think flat tappet isnt the way to go?
A hydraulic flat tappet cam will probably be at its limit if you want to maintain with 7K shifts.
Also, the hydralic cam can run flat too during break-in.
A roller cam is superior, but of course they cost more. Modern hydraulic rollers can take 7000+ with the right valvetrain.
Dennis
65' STANG, 3160 lbs
393W, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, 236/561 Solid Cam, 9.6CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 8/2/06 4:23am ]</font>
Ya, you all are right... Im just emotionally reacting to a personal crisis LOL
:cry
I would use a solid cam again.If you havent had much luck breaking in you cam. you could get cam research to break your next cam on the machine.its only $60
Try calling Comp cams. let them give you a couple of hyd. cams specs for your car and its combo.
But i think they way to go is a custom grind for your combo.
