Ok, my engine is as 65 289, afr 165's w/ 1.6 roller rockers, weiand x-celerator single plane, holley 600 dp, tri-y's, petronix recuvred dizzy,
4sp, 3.80 posi. I just ordered the heads as a B-day present to myself. I'm looking for a cam to replace my mild one in there now. Anyone have any recommendations. Car is a street/strip vehicle, seems to be more strip lately. Looking for a solid lifter non-roller cam...Thanks for any comments........
'65 2+2 TimeMachine: 289 4v 4sp 14.44 @97.29
1991 Honda Civic Si- daily driver
2002 Midnight Edition Ford Escape
<font size=-1>[ This Message was edited by: ga289stocker on 7/24/06 9:39am ]</font>
Comp 282S! I've got a very similar combo to you, Xcelerator intake, ported Windsor Jr. heads (your AFRs probably make a little more power), 1.5" long tube headers, flat top pistons with four valve reliefs(about 9.3:1), 750dp carb, and the 282S carb. It pulls real strong past 7000rpm, which I've got H-beam rods so I'm not too afraid to spin it that high... with stock rods you are probably pushing your luck going above 6500 too often, but even if that's the case the 282S would still be a great cam for you.
You may want to consider a custom cam. I ended up going that route with a comp solid to take advantge of my NOS and set up.
