Hi
Fitting the cam this evening in my new engine build. Its gone in OK but I am a little unsure about the play there may be at the end plug (rear of the engine). As you may be able to see by the pictures I've attached, there is about 10 or 12mm after the end of the Cam, yet the plug is only aprox 5 to 7mm. Do I drive the plug in further than flush with the engine casing (which I understood was correct), or do I leave the play (or space) and just have the plug flush, or is this held in place by the Cam gear?
Thanks as always for any advice
Martin
Martin
