I have a C4 from a truck with the bolt on yoke. Is it hard to convert this into a slip yoke like a car transmission?
Bolt on yoke?
Not sure i understand. But tail sections can be swaped out. You would need tail section and the output shaft.
The output shaft and extension housing must be replaced and that means tearing the transmission apart completely.
Last out first in.
Yep, replace parts or build a special drive shaft. It will be about the same cost either way.
Paul
