1 - 8 of 8 Posts
ok, i have a 66mustang, with a T5, holley 650DP, and Air-gap intake. I have 4.11s in the garage, windsor Jr. heads (MILD port and polish), a .488 .488 lift Hyd. cam. Otherwise stock 289. Can anyone put an estimate on my hp and 1/4 before and after? also i chose the .488 lift because i dont want to change pistons right now. Would a .512 lift fit? thanks
If you can get traction and you have a good tune (there is a lot to a good tune, I would do it on a dyno), you should run 12's no problem.
Check out my car, I run high 12's at 109 with a 2.08 60 ft. Your setup is very similar.
Nastystang,
The ramair system is the same as the one on project 11.99. Check the archives. I did not test it before and after, but I have to believe it is good for 2-5 mph. It just makes sense.
With your car running and fully warm, open the hood and measure the temperature of the air at the aircleaner. Mine was 150 degrees.
I read that each 10 degrees is worth 1% in horsepower, and that is not counting any ram air effect.
1 - 8 of 8 Posts
