could small jets cause a motor to not pullin hard in the upper RPM.....or would a jet change just be notice a litte on a timeslip
I've had them where 1 or 2 numbers made all the difference in the world. So I'd say yes, small changes can definitely affect top end pull and rpm.
Generally speaking, without using any sort of standard and accurate measuring device, you are unlikely to "feel" seat of the pants a change of one jet size in the secondaries at wide open throttle/
It is possible however that if you are on the border of a lean condition and detonating, for instance, a one jet change could make a difference. You'd be more likely to notice a jet change in the primaries, driving at part throttle.
In the next issue (later this week) you will see an article on carb tuning using a wide band 02 sensor (see Innovate ads on the right). With this device you can see the impact one jet change has one Air/Fuel ratio and acceleration.
Is it laying down in high gear at the track? Probably fuel delivery problem under load, usual culprit is a stock, or near-stock fuel system.
Doubtful that one jet size would be noticable in anything but a dangerously lean condition; Holley recommends stepping up in 2 or 4-size increments until the engine slows down. There is a lot of good info in their catalog, and several good books.
BOB
after it gets to 6k......it jus stops pulling like it does under 6 and i know that cam makes power past 6k.........i was just thinking there wasnt enough fuel gettin threw because of the jets being to small....but i had a stock pump on it b4 and i jus put a holley blue on soo this weekend ill see what happens
'69 fastback --302, 289 heads ported w/ big valves ,10:1, torker intake, 600DP, 294/.569 solid, C4 w/brake , 4000 stall, 4.11's
<font size=-1>[ This Message was edited by: fender2k5 on 6/22/06 3:04am ]</font>
