do you have to get the same width rim as your tire is, or can i put a tire with 12in tread width on a 10in wide wheel?
whats the widest tread width in inches that i can fit on a 10in rim?
It depends mostly on the aspect ratio (i.e. a taller sidewall will allow more width on the same rim). Look up info on the tires you have in mind, or go to your local tire shop, and they can tell you what will fit.
-Brian
