I'm scratching my head on this. I haven't had to pull/install a key cylinder into switch for year. I know the trick to get a key cylinder out but can't seem to be able to get this one to go in. The outside trim ring is fastened to the Ignition switch. When I push the key (which is in the cylinder) and push in it won't go 100% of the way. I am making sure that I line up openings plus the piece at end of key cylinder is lined up with ignition switch. When I push in it won't turn. All pieces are NORS.
Any thoughts? Install is with 62 and or 63 parts.
