first try putting on the c clips and then pull the axels outward (like your trying to pull them out of the rearend) they may move out enough to slip the pin in. another problem you could be experiencing is the spider gears may not be centered correctly look into the hole the pin goes in to see if it is lined up correctly. good luck! chris
