Hi there,I have a Sunbeam Tiger running a 347, edelbrock r.p.m. heads,9.75 compression pistons competition 268 cam I recently changed to the present cam to improve idle as the previous cam was an edelbrock performer only giving 12"vacuum as the car had been set up for track use What would be a good carb. choice for street use and what sort of power output could I expect
Tiger huh? I drove one of these once with a 289. That is quite a car. Given the light weight and it probably has a stick, I would look at something like a Speed Demon 650 with mechanical secondaries.
650 Holley DP. Should have great throttle response.
I'm running a 750 Proform on my combo, Great Carb for the $$. You motor in alot milder, Maybe the 650 proform would be a good choice.
