I'm currently running a Proform 750 DP Street Series carb on my motor and was wondering if there is a real performance difference after removing the choke horn? I've already removed the choke plate itself and the rest of those parts (don't need it here in So Cal) and added one of those K&N carb flow inhancer deals (don't recall the name) that mounts on top of the carb to smooth out the flow but wasn't sure if removing the horn would add more than these improvements.
I'm kind of overkill in this area already because I've also installed one of the "Tornado" systems inside the Spectre Cold/Ram air boxes.
What can I say? I've always been told it's an air pump so the easier it gets in and out the more power you make. :tup:
John
John
