1 - 11 of 11 Posts
My 460 has flat top pistons, the cam has a little more than 500 lift, victor jr. intake, all MSD ignition, D3VE-A2A heads. Tranny is performance built C 6/2600 stall, 9" rear end with a gear of around 4:11 and it's in a 3200 lb car. What size carb should I start with? Thank you.
We have to know the duration of the cam or the top RPM of the motor to know what size carb you need. It would also help to know what the lowest RPM you are going to go to wide open throttle.
Paul
Are you going to drag race or is this for the street - or round track?
<font size=-1>[ This Message was edited by: PaulS1950 on 8/9/06 8:08pm ]</font>
As you can tell I'm new at this motor stuff. I plan to drive on the street a little, mostly drag strip. I guess I will have to pull the cam to get numbers off of it. I measured the lift with a dial indicator while the intake was off. I guess I should have more info before I ask these questions.
Minimum 750cfm, I'd go with 850 if all you plan to do is drag race it. Don't expect too much out of that engine with the D3 heads, unless they've been ported... the exhaust ports are more restrictive than stock SBF exhaust ports.
I'm pretty sure the heads have been ported. Thew fellow I got it from had it built by a machine shop in San Antonio. He had it in a 3/4 ton pick-up and it ran pretty good. In fact the truck was more than his girlfriend could handle and she crashed it. That's how I aquired the engine.
It's REALLY easy to tell if the heads have been ported... remove the exhaust manifolds/headers and look for a HUGE bump on the roof of the exhaust ports. If it's there, they haven't been ported... if it's gone, then you're good to go
. There's a pic of the exhaust port bump (called a thermactor boss) in the fourth picture in this ebay auction (sorry I couldn't find a pic of it anywhere else on the web):
http://cgi.ebay.com/ebaymotors/429-460-FORD-CYLINDER-HEADS-REBUILT-TUNNEL-PORT-BOSS_W0QQitemZ270014768818QQihZ017QQcategoryZ33617QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
'86 Bronco fullsize, 460, E4OD
'85 Ranger, 340hp 289, T5
<font size=-1>[ This Message was edited by: Motorhead on 8/10/06 5:04am ]</font>
Yeah I agree on the intake, a Weiand Stealth would probably be a much better choice for anything that you're not going to spin over 5500rpm.
Yep, less than 900, more than 750 is what I would recommend too, if its not too radical.
Discussion Starter · #11 ·
The reason for the victor jr. was that I plan to stroke to 514 and put on edlebrock aluminum heads. It should spin up pretty good after that. I looked last night and the heads have been ported. There's a lot of unknowns since I didn't put the engine together. It may turn out to be a complete dog, but the price was right. Thanks again.
1 - 11 of 11 Posts
