my 87 stang is getting mad carbon build up in the tail pipes what could cause this???
and its a coupe bty and im trying to find those aluminum spoilers the mount to the trunk and has rods connecting it to the bumper also. any ideas???? you prolly see them on pro street cars!
new oxygen sensors, or less fuel pressure. i'd check the first option since you prolly don't have an adjustable regulator.
need to ck for codes...cold air intake readings make them run rich. since its speed density, map sensors that are intermittently failing will do it too
