not realy ford realated but you guys would have the knowledge to help.
we are trying to setup a floatless bowl using a weber DGAV carb.
the carb is going on a suzuki sierra/samuri.
we are wanting to use the stock mechanical pump with the return blocked off (or use the pump from a 1.6L suzuki, that has no return)
we need a pump to scavenge the bowl and return the unused fuel to the tank.
the suzuki pump flows 21GPH @ 2000rpm @ 3-4psi
the scavenge pump must be able to out flow the feed pump
my question is will a 30PGH carter gerotor pump live if used as the scavenge pump.
