hi there, does anyone know what the air flow of an `88, stock everything 5.0 HO (mustang) engine is, whatever the limiting factor is (throttle body i suppose).
I`m shopping for air filters and am thinking of doing something custom,.. but i`d like to not limit the flow.
cheers,
Mark
The rule-of-thumb for "average" efficiency engines at .5 lb/hr BSFC is 140 CFM per 100 hp. The formula is:
CFM = 140 * HP / 100
So, for a 220hp engine:
140 * 220 / 100 = 308 CFM
Sound small? It does compared to sales ads. But, even Holley recommends a 350 CFM carburetor as a "performance upgrade" for a 220hp engine. Yes, the CFM is generally less than most folks think, though any restriction from the filtering is bad. I try to keep it less than 4kPa or 0.5" Hg restriction for a daily driver. Too big is not a problem of course. Attach a vacuum gauge between the filter and throttle to directly test for losses -or- read manifold vacuum and run the engine no filter/with filter to compare added restriction.
:tup:
