I have a 23 T roadster on a MustangII frame with the V6 motor and standard shift 5 speed trans. Is there a Ford V8 that will bolt up to this trans and motor mounts.
<font size=-1>[ This Message was edited by: retfuzz7 on 10/15/06 2:59am ]</font>:
<font size=-1>[ This Message was edited by: retfuzz7 on 10/15/06 3:01am ]</font>
You can use a ford 302 V8, but have to get the frame and motor mounts I think. make sure you use the Mustang II bell housing if u plan on using headers...I did a V8 Swap on my 78 Mustang...so if ur using the frame these may be an issue...hope it helps....good luck!!
