Can anyone tell me if this matters? What I have is a speed density 5.0 that I bumped the compression up to 10.5-1,and I was wondering if the computer will be alright. The rest of my combo is stock H.O parts,the heads have some work done to them but that is it. Any insight guys?
You should be okay. I have an 86 (now used for parts). The only thing you need to worry about is if you change the cam. I changed the cam in mine and the car would barely run. However if I were you I would make the change to mass air, that way you can upgrade you heads, cam, MAF, injectors and so on.
