Do this, it's easier and quicker...
Take out the #1 plug. Place thumb over plug hole.
Bump the starter untill you begin to feel a WOOSH... Immediately stop. (you will need someone else to bump it unless you have a remote starter jumper)
When you feel the woosh, immediately look down into the timing marks and with a wrench back the motor up to TDC then 1/4 turn before TDC then back to TDC. (that takes about 10 cesonds)
Place the dist in the motor and just point the Rotor any which way until it snaps down so you CAN SEE HOW FAR THE ROTOR TIP MOVES WHEN SLIDING ALL THE WAY DOWN.
PULL THE DIST BACK UP> MOVE THE ROTOR POINT FOREWARD the SAME DISTANCE before the #1 in the dist cap would be, that the rotor twists when fully seated... Remember the amount of travel on the rotor tip from touching to fully seated, that's what I'm talking about.
WHen you have the point at the approximate place, slide the dist gear into the cam gear untill it stops. If it stops short you should be about 1" to the LEFT of the #1 position on the Cap. (while this is going on hold the vacuum buld in the center of the adjustment radius allowed for movement)
If it didn't stop short and slid all the way down that's GREAT! (but only as long as it points to #1 on the cap.
IF It DID stop short and is still the 1" give or take from the #1 pointer on the cap's position that is good, all you must do then is bump the starter a time or two and it will drop down on the oil pump shaft without getting out of the adjustment you wanted.
Now you can re-assemble and start and set the timing.
I hope that was clear... It only takes about 5 minutes...
FE
