So, to get my little 68 falcon on the road, I was hoping I could use the 6 cyl c4 for a time (I have a built AOD I will be using later on, but need to save up for drivelines, rearend, crossmember, rims/tires for v8, ect) 6 cyl is blown up (valve dropped), no reason to put it back in. I have a bone stock 351W that I will be putting in the car. I know it will be hard on the 6cyl trans but for now that is what I would like to do. I have a couple questions.
I have the bellhousing for the v8 c4 and and I want to know how hard it is to swap. I took a c4 apart once, but can't recall exactly how they go together, or if it is technical to do...
also, will I be able to use the 6 cyl trq converter on the 351 flexplate? flexplate came from a c6 or aod trans, I can find any flexplate if need be.
thanks!
thanks!
