Ok I'm going to tackle this project soon on all four corners and I strayed a little from the original post but here's what I ordered:
1 84 Mustang SVO disk/disk master cylinder
4 75 Impala calipers, two left two right
4 95 Crown Vic rotors (I'll be reusing my original hubs)
4 hubcentric rings. Wheel Hub Centric Rings - buy wheel hub rings online from 1010tires.com
4 18" braided SS brake lines. Brake System Equipment - Longacre Brake Line 18" Long, # 4AN X 3/16 ends
2 banjo fitting kits. GM Caliper to AN Banjo Fitting Kits
4 weld on GM caliper brackets. GM Weld-On Flat Mount Standard Caliper Brackets
I'll be picking up the grade 8 bolts and spacers locally. I'll post up pics and results when I'm done.
