The weight is the main diff of the 2, and well of course the price. Aluminum heads will run you a premium. Iron is what the rest of the block is made of and is much heavier but also stronger and less likly to flex or expand when it gets hot.
Yeah, if the engine gets too hot, the aluminum heads will expand more than the block, and blow a gasket. Happened all the times in an old car we used to have, Went through about 5 of them.
Are you sure there is such thing?
I didn't even know they made aluminum cleavland heads! Please post a pic or link to what they look like, if they exist.
I belive the 351C uses the same heads as the 385 series blocks and there are all sorts of aluminum heads for these blocks. Give summit a call and I am sure they can work something out for you
<font size=-1>[ This Message was edited by: BobCat on 6/17/02 10:36am ]</font>
FYI. 351C heads and 429/460 heads are NOT interchangeable.
