For you 4 speed guys How do you like your 1st gear? Anyone ever try both? Thanks
Keep in-mind the purpose of each. Wide-ratio allows a selection of deeper gearing when required. Close-ratio allows the driver to keep the rpms in the best range for the engine, but in a fairly narrow band. So, in a general sense, wide-ratio is for driving, and close-ratio is for racing. Consider that drag and road racing cars only pull-away from a stop once during the whole race.For you 4 speed guys How do you like your 1st gear? Anyone ever try both? Thanks
This is good stuff! :tup:Keep in-mind the purpose of each. Wide-ratio allows a selection of deeper gearing when required. Close-ratio allows the driver to keep the rpms in the best range for the engine, but in a fairly narrow band.
In a racing sense, I prefer to look at it as close ratio is more for road racing and wide ratio is more for drag racing. I wouldn't do so well in the 1/4 mile drags with the close ratio 2.32 first gear, generally speaking.So, in a general sense, wide-ratio is for driving, and close-ratio is for racing. Consider that drag and road racing cars only pull-away from a stop once during the whole race.![]()
Recount the 2nd gear teeth. I believe that there is a mis-count=you should get either the 28 or 31 teeth. First gear is 32 teeth (as a matter of fact, it is the same exact gear in both-the cluster determines the 1st gear ratio.)
Otherwise post a pic of the gears with the cover off.
Sorry, I don't know anything else about your "toad" other than it's heavy.How do you think it will act with the 3.70 rear?
Car is a 69 so she is a toad.
Stock engine for now but building a fuel injected 351w with pro comp heads and 10:1 pistons, nice little cam.
What kind of RPM's will we be winding on the hiway? We have Decent tall tires in the rear, like 28-29"
The gears seem pretty steep on the hiway with the auto.
Do yourself and your country a favor, buy an American casting. You'll thank yourself later. A lot of these Chinese junk knockoffs have to be gone through and have been known to drop valve seats.with pro comp heads .
IF you need something cheap, buy used there are plenty around.
Btw I've opted to get a wr built with a 1 3/8 input. Even with 411s. 4k pounds is tough to move.
