I can't find my install sheet and the Cloyes website is useless. Does anybody have the info that documents what the symbols mean? Theres an O, a triangle or diamond shaped pointer and a block. I guess it would have been too easy to just put 0, +4 and -4 on there. Something that is puzzling to me is that the keyway slots on the crank gear look evenly spaced around the gear. It seems to me that this would be more than 4 degrees plus or minus?
Also if you are advancing the cam timing does this mean retarding the crank to put TDC later? My brain is confused.
