so my cloyes timing set has 3 different keyways on the crank gear for 0, advance or retard, but they are all different shapes, does anyone know what shape refers to what timing position?
I just installed a Cloyes Hex-A-Just timing set, and here's what the instructions say:
The square keyway is 4* retarded and uses the Y timing mark on the crank sprocket
The curved bottom keyway is straight up and uses the O timing mark on the crank sprocket
The v-bottom keyway is 4* advanced and uses the * (solid dot) timing mark on the crank sprocket
thanks for the info but i still have a question
Currently my crank has the square woodruff key installed that would result in 4 degree retarted cam if I line up Y to dot on cam.
I need to install the cam at 0 (straight up) so do I have to get the woodruff key out to change it for a curved one?
or are you saying that even if I use a square keyway I can just line the cam dot with the 0 mark on the crank?
All 3 of those shapes should slide over the regular woodruff key. Because they are still squares with either a curve on the top or a V.
Slide the cam sprocket off and re-position it so the curved keyway slides over the woodruff key.
Then use the O timing mark on the crank sprocket.
<font size=-1>[ This Message was edited by: 89Trooper on 9/7/06 9:05am ]</font>
