Sound wierd, but I want to go from my auto to a T-10. Have the bell housing and pedal assembly. Instead of the Z-bar, could I hydraulicly slave the clutch? Dont know if my headers will clear otherwise.
Tracy
I made my own from junk yard hydraulic parts and rebuilt them.Do make sure you have good alignment with the slave pushrod and another trick is to put a rod end on the pushrod where it works on the fork, stops wear.Different master/slaves work for pedal feel and fork distance.
The HP clutch and flywheel book has some useful tech on this too.
