Do you have a feeler gauge set? If so put everything together and check the gap from the snap ring to the top retainer ring. Shoot for .005" per clutch disk. If 4 then .020". If you have 5 you want .025" . make sense? I run 6 per pack by using thin steels and custom machined retainers and/or thin snap rings . You can adjust with thicker or thinner steels or clutches or snap rings or retainers. Simple stuff but it makes you think.
438 inch Dart block Windsor, AFR 225 heads, 271/
[email protected]" on 106 solid roller, 13:1 compression, Super Victor, crank trigger, 950 HP carb, external wet sump oiling, reverse manual C4, 4000 stall, 4.10 Dana 60, Nitrous. Stupid fast street '68 Cougar
<font size=-1>[ This Message was edited by: chipmechanic on 5/25/06 4:17pm ]</font>
