What size throttle body do I need for a Cobra intake? It says the egr spacer is built in so I'm assuming I have to match the size of the opening but I can find anything that tells me what size it is.
Discussion Starter · #2 ·
1 more question. Is there a difference between the new reproduction cobra intakes and the originals? Do they flow the same? Thanks guys.
The stock '93 Cobra t/b was 65mm.
I've heard that the Chinese made Cobra intake available in the Ford catalog is a bit rougher casting than the originals and flow is down a bit.
If you get one of those you can always have it ported by TMoss:
http://www.tmossporting.com/tabid/310/Default.aspx
Both the reproduction and orignal Cobra intakes are on ebay pretty regular.
I got a real nice original upper and lower for $330 shipped. Which also included the t/b.
65mm is all you need. Any larger won't make a difference because your intake opening isn't that big.
The reproduction Cobra intakes are the same as the original except for the logos.
www.fakesnake.com
<font size=-1>[ This Message was edited by: fakesnake on 12/29/06 2:16pm ]</font>
