Thank you for your reply. KOEO at "I" was 7.2 volts, but voltage at coil was only 5.8. Maybe time for new wiring. The resistor was put in to intentionally drop primary voltage to the coil? I'll check when able with engine running. Thanks Tom G
Tom, I have a wiring diagram of the basic circuit I'll post when I get to the other computer, but the "I" terminal and coil are on a Y-wire, joined at the firewall. The "I" wire is usually BROWN and the coil wire usually RED/GRN. Between the firewall and the key switch is the PINK resistor wire. The purpose of the PINK wire is to reduce current through the coil, and in doing so, also reduces the voltage when under load. If the circuit is not under load, the wire should show full battery voltage.
So, KOEO would have full battery voltage through the firewall to both terminals. As there is no load, you see full voltage. However, if you have points or certain 'dumb' points-replacement electronic ignitions, and the points or circuit happen to be closed (charging the coil), you will see lower voltage than the battery. My bad - I should have listed the "what if". Test again after disconnecting the coil (+) wire to verify full battery voltage at the disconnected end of the coil wire.
When the car is cranking in KOES, the starter relay (solenoid) closes contacts and sends full battery power out the "I" terminal to the coil for better spark during starting. This bypasses the PINK resistor wire during cranking only. Again, you should see battery voltage, though the entire system will be lower voltage due to the starter load.
Once running, and the start relay disengages, coil power is through the PINK wire only. The effect is to lower the available power to the coil, giving a running voltage of 6 to 9 volts. Why? Because we really would like full battery voltage to the coil at all times, but if the car stalls or the key left KOEO for any reason and the points are closed, the coil will cook at full battery power. So, the PINK wire is used to ensure it doesn't fry. That is the sole purpose of the resistor wire and the need for the "I" terminal.
You can see how a change to a 'smart' electronic ignition module could simplify the wiring, while improving spark during KOER, and still protect the coil when KOEO.
