Here's a quick rundown. I was in the process of rebuilding my front end with all new bushing and inner and outer tierods disc conversion. While I was doing that i wanted a stiffer front (new springs) I wanted to buy or make some roller spring perches and add some better shocks. 100 a piece for shocks,100 for new springs and 40-200 for roller perches. Had to be a better option so I started looking at coilovers and the cheapest I found was 600. I know QA1 coilovers are cheap and work well from my experience so I measured shock compressed and extended length, and also spring diameter. Then I started looking through QA1 website and found QA1 501C for 70-'81 Canaro/Firebird. So to not drag it out anymore I paid 400 got rid of the perches and have adjustable ride height and shock valving . Here is the pics of the install. Any questions about anything just ask
This is the shaft/mount that was originally in the spring perch. The shocks poly bushing is for 3/4 and the perch mount is 7/8. I had access to a machine shop and turn the shaft down to 3/4" about 2/3 across the mount and then machined in a groove for a snap ring. QA1 make a T-bar that is 5" instead of 3" that comes in the kit but i never measured the distance between mounting holes on the upper A-arm. Another option would be to drill out the bushing to 7/8
The shocks poly bushing allows the mount to spin freely by hand so no binding from the solid rubber mount of the original perch
