what are the common spot for a c4 trans to leak? i know the one i pulled out of the car was leaking. i just dont know where from.
i already plan on...
changing pan gasket
front seal
tightening the modular if its loose
i read somewhere that the actual shift linkage leaks sometimes too. is this fixed by just undoing i think it was 1 big bolt or 2 small bolts (id have to go look at it agaiin) and cleaning the surface and puting it back on? is there a gasket/oring for it?
is there anywhere else that you can think of that might be leaking? oh i also dont think its leaking where the front case and rear case meet
changing pan gasket
front seal
