Trying to figure out what the compression ratio would be for the following:
1995 351W stroked to 388ci with a 3.85" stroke crank, deck height is 9.5", not bored,
stock length rods at 5.956",
stock Ford forged 302 pistons w/1.605" compression height out of a GT motor but I don't know what the dish volume is,
GT-40P heads w/61cc chambers, stock valves for now,
Cam will be around 0.510 to 0.540 lift max with an overlap around 112 deg.
I'd like to be close to 10:1 or just above, will mill the heads if I have to. If I knew what the piston dish volume was for a stock GT forged 302 piston was I could probably get an answer, heres a good link for figuring the compression:
http://www.torinocobra.com/Randys_tools.htm
